Adding an Operator:
Log into your account:
- Begin by logging into your Trucker Path Fleet Navigation Portal using your administrator credentials.
Navigate to the User Permissions:
- Once logged in, locate the More tab in the main navigation bar at the top of the screen.
- Click on More and select User Permissions from the dropdown menu.
Access the Add Operators Screen:
- In the User Permissions section, look towards the upper right-hand corner of the screen.
- Click on the Add Operators button.
Enter Operator Details:
- A form will appear, prompting you to enter the following details for the new operator:
- Email Address: Input the operator's email address. This will be used for login and notifications.
- Phone Number: Enter the operator's contact number.
- Name: Fill in the operator's full name.
Terminal Assignment (Optional): If applicable, assign the operator to be in charge of a specific terminal.
Add Multiple Operators (Optional):
- If you need to add more than one operator, use the Add New button to bring up additional entry fields.
- Repeat the process of entering details for each additional operator.
Save the Operators:
- Once all necessary details are entered, click the Save button.
- A verification email will be sent to the email address provided for each new operator.
Removing an Operator:
Locate the Operator's Profile:
- In the User Permissions section, find the profile of the operator you wish to remove.
Initiate Removal Process:
- To the right of the operator's profile, click on the ellipsis (three dots) to open a menu of options.
Delete the Operator:
- From the menu, select Delete to remove the operator.
- Once deleted, the operator's login credentials will be deactivated, and they will no longer have access to the fleet portal.
Questions?
If you have any questions regarding this topic or any others, please reach out to our Support Team via email at fleetsupport@truckerpath.com.
Comments
0 comments
