Key Topics
The following guide will guide you through Creating a New Group, Setting Permissions and Routing Profiles
Creating a New Group:
Log in to NavPro (or Command):
- Begin by logging into your Trucker Path Fleet Navigation Portal using your administrator credentials.
Navigate to the Groups Section:
- Once logged in, access the "Drivers" tab from the main navigation bar.
- Click on "Drivers" and then select "Group" from the options.
Access the Add Group Screen:
- In the Groups section, look towards the upper right-hand corner of the screen.
- Click on the "Add Group" button.
Enter the Group Name:
- A form will appear, prompting you to enter the name of the group you want to create.
- Enter the desired group name in the provided field.
Add Drivers to the Group:
- To add drivers to your group, click the "Add Driver" button.
- A list of available drivers will appear.
- Select the drivers you want to add by checking the box next to each driver's profile.
- After selecting the drivers, click "Add" to include them in the group.
Review Added Drivers:
- The selected drivers' profiles will now be listed at the bottom of the page, showing all drivers assigned to the group.
Setting Permissions and Routing Profiles:
Assign Driver Permissions:
- Use the "Permissions" tab to assign a specific profile for the drivers in the group.
- Select the appropriate profile by clicking the bubble next to it.
Set Routing Profiles:
- Routing profiles dictate the parameters that will guide all drivers in the group.
- To set the default routing profile, toggle the switch on the right-hand side.
- You can also add more profile options by selecting additional checkboxes on the right.
- These options will be available for drivers within the app.
Save the Group:
- After configuring the desired settings, press "Save" to create the group with the selected drivers and profiles.
Comments
0 comments
