Option 1: Download over Wi-Fi with certain connections blacklisted
- Let your customer success manager know the exact Wi-Fi name you would not want the Offline Maps to download from. We will blacklist that connection so it will only download on other connections.
- Within the Fleet App, Navigate to Me tab, tap on Offline Map
- Tap on Get Your Map Now
- Select the United States Map
- Tap on the Download Icon
- The map file size is 10 GB, the download may take up to 1hr, pause and resume as necessary
- Successfully downloading the Offline Map will show under Downloaded
Option 2: Install via a wired connection to the device
- Plug-in external USB drive to tablet
- Within Trucker Path, go to Me tab, tap on Offline Maps
- Choose Install Map from Flash Drive
- On the top left menu icon, Open from the plugged-in external Drive [NO NAME]
- Go to the folder named TruckerPath
- The Truckerpath filder contains all the data files required to transfer Offline Maps. Press SELECT without tapping on the individual files.
- The transfer will take around 10min to complete installation. Do not quit the App during this process. After successfully installing, it will show under Downloaded
Questions?
If you have any questions regarding this topic or any others, please reach out to our Support Team via email at fleetsupport@truckerpath.com.
Comments
1 comment
How do you use the offline map when you have no service? My app will not load any address and is not useful at all without cellular connection while in the road. I have to use google maps offline maps to get me out of the spot I’m in while I wait for cellular connection to get back on my phone to continue using the app.
